Going from manual crank windows to power
Preston
Mechanicsville VA
Preston
i was able to find a pair of doors that came off a Truck with power windows and locks. I will be replacing the ones on my K1500 that had been stripped of all hardware. My question is when hooking up the power to these doors how difficult will it be? The wiring was unplugged from the donor truck all I have to do is rewrite from the doors to the fuse panel? Any suggestions or comments thanks for the help.
dvdswan
Port Orchard, WA
Dave
Its not difficult to do. But since you will have to wire it, I suggest adding the relays. Just follow the wiring diagrams and write ups on the relays.
Camar068
Kentucky
10 yrs Air Force
he'll need the harness inside the cab right? I'm looking for one.
Preston
Mechanicsville VA
Preston
If I find 2 I’ll send you 1
winfred
