- Oct 27, 2016
- MO
- Spencer
- 1971, 1̶9̶7̶4, 1976, 1979,1̶9̶8̶5, 2002
- Dart Swinger, Sierra 10, C10 Cheyenne, C10 Big Ten, Silverado 10, Ram 2500
- 225/6, 350 c.i., 350 c.i., 5.9l Cummins
An IDI should start without glow plugs, it might take some cranking and maybe some starting fluid, and it may not be happy at first, but it should go.
Watch on youtube some videos of the "Slave Lake" Ford with a 7.3 IDI from Zip Ties N Bias Plies, that thing has ate enough ether for everyone with various degrees of glow plug function.
Was the truck running in the past? Was it hard starting before or? Blowby while cranking?
If you sprayed too much solvent into its throat it can wash the cylinders enough to lose compression and make it a real bear to start. A little transmission fluid down its throat can help it build compression and get running and let the rings reseal and reseat.
