Gilmer Belt Kit
ditzr
Pontypool, Ontario
Rod
C15
Hey all, Happy New Year..
I have a quick question.. I have been in the process of gathering parts as i find them at good prices, in preparation for when i start the assembly of my 75 GMC C15 Long Box.
In the past I had built a 66' Mercury Comet 2dr Hdtp with a 302/HO and T5 manual trans.. a lot of fun.... but my passion has always been for the squares. to be different with the Merc, i installed a serpentine belt system that was awesome to look at and trouble free... i want to do something different with this build.. i think i want to install a Gilmer belt kit.
the kits that i have seen all support the crank, water pump and alternator, but it is not clear whether they will support power steering.. some kits specificaly state they do not, but i would like to find a bolt on kit that will..
do any of you have experience with these kits and could you recommend a manufacturer for such a kit??
thank you
rod
gpmorgan
Tupelo Ms.
greg
This is one of their sets I installed on my engine.
74 Shortbed
I believe he's looking for a Gilmer belt kit not Serpentine.. IIRC you have to do the PS separately, or just make up your own???
gpmorgan
Tupelo Ms.
greg
I was referring to the last paragraph of his post.
gpmorgan
Tupelo Ms.
greg
My bad. Your are right. What's a Gilmer belt?
gpmorgan
Tupelo Ms.
greg
I found some. Yeah I like that belt too.
74 Shortbed
Yeah, and he's referring to Gilmer kits, all you see is water pump and alternator no PS included, would have to use a second belt..
ditzr
Pontypool, Ontario
Rod
C15
thank you for all of your input.. some of the kits have an extra groove on the crank pulley, which might be capable of running the PS off of... well, i have lots of time, so i thought i would throw it out there..
i had also heard that the gilmer belts make an awesome sound..
74 Shortbed
Since they are a cog type belt air gets trapped in the groove of the pulley as the belt enters the groove, the sound is the air being squeezed out by the belt, if you listen to an engine with a blower you can hear a whine when revved up, people think it's the blower whining but it's the belt, some don't like the whine and drill small holes in the pulley to let air escape
ditzr
Pontypool, Ontario
Rod
C15
thx for the explanation.. makes sense...
