Gears
fnny6770
Pocatello
3500 camper special
My 1980 GMC 1 ton truck came from the factory with four 10 gears 400 engine and a th400 tranny, my brother put a 454 in it with a three speed manual transmission and it seems like the differential gears are too high, my question is what size differential gears would have came with a manual transmission?
idahovette
Weiser Idaho
Perry
K20-K10
You are gonna have to define "too high".....too high engine speed(RPMS)? or it lugs the engine?..(doubtful) Please, more info
nvrenuf
Mobile, Al.
@fnny6770 there is no set ratio with auto or manual transmissions, a 3/4 ton (or 1 ton) could have come with 3.73, 4.10 or 4.56(rare). What actual ratio came in a truck is dependent on the options ordered.
Shorty81
Baby Boomer
North West ohio
Darren
My 86 3/4 ton 3:73, 208 transfer, 31" tires with the sm465 manual runs 2000 rpm at 55. I'm really happy with my gearing, I rarely get over 60 mph. If I need to creep around the woods I have low range and the creeper 1st gear.
Old Guy Bill
KY
Bill
As previously posted we need more info..
Is it “Too high” when traveling in high gear, or “Too high” when trying to take off in low gear?
Please elaborate
fnny6770
Pocatello
3500 camper special
I misspoke, it seems like the gears are too low I haven't driven it in many years but it seems like at 50 or 55 mph the tack is anywhere between 25 and 3,000, my father ordered this from the factory so I remember the Gear ratio is 410, but pictures will have to wait because my truck is at my daughter's house 60 mi away or I might could possibly find some older ones to post but it just seems to me that 410 differential gears was because of the automatic transmissions gear ratio, it's a camper special
fnny6770
Pocatello
3500 camper special
It's very Rusty and all of the factory badging has fallen off or been removed, did I mention it is a 4x4?
fnny6770
Pocatello
3500 camper special
It's the only truck I've seen that came with shock absorbers, from the factory mounted in the bed of the truck that mount to the cab
Camar068
10 yrs Air Force
maybe drop a 700R4 or 4L80 transmission in it? It'll give you a 4th gear.
[edit] nevermind, you said it was a 3 speed manual.
Actually,not a bad Idea. It started life as a th400.A 700r4,leave the pedals as is just a spring to return the clutch, the column probably wasn't changed. Then he'd have gearing for work and decreased rpm on the highway. But @fnny6770 any mods you make to slow the highway rpms down are going to be expensive and you will still have to buy gas. You will have to put a lot of miles on this truck to break even in gas savings.
jlyon1006
