Logbed
- May 31, 2022
- Finland
- Juha
- c10 Fleetside Silverado
Hi,
I'm going to swap the engine to a bit punchier sbc with a GM Performance LT4 Hotcam (219/228deg, .525/.525 lift https://www.gmperformancemotor.com/parts/24502586.html ) and also the I might need to adjust/replace the gear for it has a rather loud engine braking noise so gearing change is an option too.
The truck is driven mostly in town and smaller roads, hardly ever faster than 55mph. Checking with a gearing calculator I ended up with two gear options: with my 31" tires and overdrive trans, a 4.11 gearing is 1700rpm at 55mph and a 3.73 would be 1550rpm at 55mph. I was wondering would I really benefit at all from a taller gearing considering the LT4 hot cam may like some revs to run smoothly? In other words, what kind of cruising revs should be the goal with the LT4 Hotcam?
