Gauges not working when headlights are on
Lugnut
Northwest Georgia
Jason
'79) 350/ granny 4-speed, '86) 350/A833 3-speed with overdrive
I woke up to snow again this morning in north Georgia, so I drove my '79 K20 to work. I noticed this morning that when I turned on my headlights that I had no dash lights, the dash blinker lights came on, my gas gauge went to empty, oil pressure went to 0, and heat gauge went beyond hot. If I turned my lights off everthing goes back to normal. I haven't had time to look into it yet, but hoped someone might have an idea where to start looking.
Thanks
My '77 did that once, it turned out to be a bad spot in the cluster's printed circuit. It was repaired by soldering in a bypass wire to go around the bad spot.
Lugnut
Northwest Georgia
Jason
Thanks, I checked fuses and grounds, but I haven't pulled the cluster out yet. Will do that this weekend once all this snow is out of here and it warms up a little.
Oh, and IIRC, the bad spot was in the ground trace around the perimeter of the cluster. I think it was near an edge and moisture probably got in between the layers over time. It's been a few years though, so I could be talking out of my ass at this point ;)
Lugnut
Northwest Georgia
Jason
Thanks bucket for the heads up. I pulled out my cluster yesterday to find that the printed circuit had started coming apart, and some of the copper had broken. I had another printed circuit laying around and changed it out and everything is working again.
Tried to post it up last night but couldn't find it everything got moved around.
nbrizjr
