Gauge Cluster Question
Steve Sandman
Fletcher, NC
Steve
K30 3+3
Instrument cluster problem/question -
A couple of my gauges didn’t work so I purchased a used but working (according to the seller) gauge cluster. Once I installed it, looked like everything works but when I turned on the light switch, all the gauges went whacko and the turn signal indicators turned on. My guess is that it’s a ground issue, maybe.
So, instead of installing the whole cluster, I removed the fuel gauge from that cluster and put it in my original cluster. Reinstalled my original with the swapped out fuel gauge and the exact same thing - turn the light switch on and the gauges went nuts and the turn signal indicators both came on.
Any ideas? What have I done?
Scott91370
Burleson, Tx
Scott
Sierra1500
I'd start by switching the moved gauges back and testing the original cluster to see if it was permanent damage.
Then you'll have to figure out if it is just the fuel gauge that is messed up (which would stink since that is the one you needed) and why. I don't have a better answer but testing is where I would start.
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
Check the contacts where the harness plugs into the printed circuit. They’re delicate and sometimes corroded and that’ll cause a ton of problems. Basically you have to clean each bare spot of copper where the gauges make contact to and the wire harness plugs into as well.
Ben
jlyon1006
