Gas tank replacement
Shilaeli hugger
Ohio
Burdaddy
V20
Well after months of searching i found a nice used southern tank and a frame bracket for my moms 86 c10 long bed. My question is, what should i use between the tank and bracket? I know it originally had.some kind of material in there. I have.the old rubber floor pieces and insulation from my 87 cab. Would any of that be ok?
Oldrider
NC
k2500
Hoping the other guys will respond. I replaced my tank (85) some 12 years ago and I don't remember what I used. I think it was some old rubber belt from work.
bedwards
Adger, Al.
Bryan
c10 Silverado
i used old fire hose on a old car that i have
75Monza
Colville, Washington
K30, K20, K20
I've used strips of old inner tube before on mine, used spray adhesive to hold it on the bracket.
Camar068
10 yrs Air Force
I saw someone mention roofing tar paper as well.
I sold some of those on eBay until the secret was out. You can make them out of heavy roofing paper. I had them cut to factory sizes and they were legit as they come. But if you can find a scrap of heavy roofing black tar paper and there you go.
Hell, if I could remember where that roll of roofing paper I have is at in storage, I'd make you some and mail them to you. Folded up, they can ship via First Class Mail for about a buck.
Shilaeli hugger
Ohio
Burdaddy
V20
Im about up for it. I cut pieces out of my old rubber floor and this is bein a headache. Id post a pic of the stupidity i ran into but it wont let me. Lets just say i have good reason behind hating anyone that takes a truckto powerline park in ohio. They coudnt drill out the rivets on the strap so they cut, then drilled a piece then drilled strap and bolted piece to strap.... just so they could go be 'country'.
I used a yard stick and a razor knife to cut that roofing felt paper. They came out nice and straight without any problems. They looked all as good as factory pieces, maybe even better because I think the stuff I used was a hair thicker and I think actually worked a bit better.
spanky1205
Middle Tennessee
Anthony
I used a couple pieces of old tie down strap that truck drivers use. Worked perfect.
seanhatesregister
