Gas tank fuel lines for rear tank
GMC_Nick
pittsburgh
Nick
350 sbc
So this is sort of an open idea question. I'm relocating the gas tank on my truck to the back using a blazer fuel tank which I have mostly figured out. The question I'm thinking about is suburbans also have rear tanks so realistically could I just buy pre bent suburban lines for the new gas tank for a truck that has a gas tank in the rear and run rubber lines from the sending unit to the hard line? I know the frames are slightly different between trucks and suburbans but maybe the fuel/return/vapor lines could be interchangeable? I'm new to running fuel lines so maybe I'm wasting my time thinking about this but I'd prefer just to buy pre bent lines online if possible. Thanks folks
I used the fuel lines and brackets from a 97 K2500 suburban that I had for a parts rig. I just re-bent the lines a bit to fit and ran them from the back tank to the hard lines where my switching valve used to be. They attached right to the blazer EFI sending unit.
I'll be installing the rest of the lines including the in-line filter when I do the EFI 454 swap.
