Gas spilling out filler neck while driving! 1977 C-10
Vintage_Phinds
PA
AC
1977 & 1986
C-10
I've had this 1977 C-10 that spills gas, while driving, from the filler neck even when 3/4 tank full. Is this common on the 1977? I had a 1979 and a 1981 with no issues. Any recommendations?
ASPEC
C2500
If fuel is getting past the fuel cap then you need to replace it with a proper new cap. That year should have a vapor recovery system and the fuel cap should only be vented into the tank when under vacuum, not to atmosphere.
Make sure your charcoal cannister under the hood is hooked up correctly.
JoeyPepperoni
