Fuse box from 80ish up square?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Anyone in readerland with a seriously hacked up wiring harness?
I’m looking to install a ATO style fuse box in my sons 71 El Camino. This will be a Frankenstein project, but nothing we didn’t anticipate.
I built my own dash harness years ago for my 69 Olds. I used a fuse box and bulkhead connector from a 80 GMC truck, it fit the dash opening perfectly, as will the El Camino. I don’t need a dash harness, as long as I have the fuse box, the 3 matching plugs and as much of the wire coming out the top of the fuse box I’ll be good.
A added bonus would be the chime module and matching plug. While the key in the ignition buzzer is annoying, the headlight on warning is a plus.
Thanks!!!
This is the style fuse box I used.
Ive got an 84 c10 parts truck,its pretty stripped and Im super busy so stay on me so I dont forget if it's there and decent you can have it. I bought the truck already stripped for the engine and transmission thats why I dont know if it has a fuse box
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Drop whatever trivial thing you are doing and deal with my concerns IMMEDIATELY!!
Ok, whenever you get a chance check it out and get back with me. Thanks!
In kansas city until Monday night. I did look before I left. Fuse box is present.trucks been sitting since2015 no glass,in the truck.I'll try to pull it and check corrosion etc. Tuesday.
Terry Wilkerson
Kansas
Terry
GMC 1500
This guy has one. He is in Kansas City area.
I'm about to pull all the wiring out of my 85 Blazer. I'll not be reusing it. I'll take some pics. If it is what you are after you can have it. Pay for the ride.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Sounds good! Thanks.
While in Kansas City today I took this pic for you. Can't remember where we were talking about butchered toros or I'd have put it there.
Finally got a minute to pull it. Looks fine P.M. your shipping address I'll get it in the mail to you.
I got mine pulled also... I guess you can take your pick.
Okay. I'm going to mail mine,to you. You mail them both to Matt. Just kidding.
jbahena95
