- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
You have a DVOM? Just do a voltage drop test.
Set your volt meter to DC volts, Touch negative lead to Battery negative POST, then touch your Positive lead to the case of the sending unit. Observe voltage reading. Anything more the .03 - .05 volts is excessive.
Another way to test for voltage drop is to:
1. measure the battery voltage at the battery POSTS. Record your readings
2. Connect negative lead of the multimeter to the case of the sending unit.
3. Connect positive lead to Battery Positive POST. Record your readings.
You shouldnt see anymore then a .03 volt difference from testing direct to the battery versus the sending unit case.
IF you see more then a .03 difference then touch the negative lead to the engine block, should be within .02 volts of battery voltage.
Your questions brings up a question for me though. There seems to be alot of electrical questions and problems from time to time. I have been thinking about doing a techincal write up on Proper procedures for testing electrical systems.
Would this be something that anyone would get any use out of or would I be wasting my time?
I'm certain a select few would get use of the proper technique to electrical test. I always look at book in most cases, like to test sensors, coils (both sides) and modules and such. I don't even bother trying to memorize since I know I'm going to going to have the look up the specs anyway.
On this Temp guage and the voltage test... So a Volt reading is the way to do it huh? So I got this all wrong then. I figured the gauge was 12v hot as soon as the key comes on, then then the sender grounds through a thermistor however spelled, or thermal resistor, and the ohms measured through the thermistor is what made the guage read, and why with a grounded out gauge wire is why the guage pegs infinite. In short that's what a guage is in most cases. It's actually a ohms meter with a different scale.
I think what I'm testing here for is a defective NEW or WRONG Sending Unit. Being the gauge Parks where my other Temp Guages Park without power, and that it pegged infinite when the wire was grounded, is telling my, my wire is good and that I have the right wire on the sender, also another tell tale that the gauge should function. So I"m expecting either, the Teflon Tape is not allowing a ground to the head, #1, The sending unit is wrong part #2 or that the sending unit is DOA out of the box #3.
So I'll give that a try, maybe that's why I've not figured this out yet. I also haven't looked at any books yet either.
