- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
Best advice I can give is mount it as close to the tank as humanly possible and as low down towards the bottom of the tank as possible. So right near the switching valve and basically mounted to the bottom of the frame rail. That will make it pull no more than to the top of the tank just once to initial prime and then it will be mostly pushing fuel up to the engine and will be siphon fed from the tank, which shouldn't put too much strain on it. I would also recommend you wire it so that it is direct fed power through a 10 gauge wire from the battery. Use a relay to turn it on and off with ignition. Run the ground direct to the frame also using 10 gauge wire(as long as you have a nice big ground wire from the frame to the battery)Yes the cam should have the lobe for a pump, whats an electric pump I can get relatively affordable? It’s got just cheap parts store pump on it and another burnt up one inside of it. Guy had it mounted on the firewall I moved it to the frame
