Fuel gauge issue
NC
E.B.
V10 Burb
My fuel gauge reads incorrect. When tank is full it reads at 1/4. When at half a tank it reads at 1/8. Any thoughts folks?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
Are any of the other gauges acting weird? If not I would concentrate on the tank, check the ground and sending unit wire. If the sending unit is original it may just be wiped out.
On the other hand, I had a fuel gauge in a Camaro act the exact same way and it was just a bad gauge. The truck gauges and Camaro gauges are basically the same.
spooky
wiggins ms
luke
silverado R10 swb
check your fuel sending unit. mine rusted through. There was a male connector in the base that rusted off.
NC
E.B.
V10 Burb
Well when the dash light are on only half of the dash lights up. I also replaced the floater in the tank and that didn't fix the issue
NC
E.B.
V10 Burb
Thanks for the advice fellas. I will see if that fix the issue
crazy4offroad
K-10
350/SM465/NP205
Dash lights could just be bulbs, but it could also have something to do with the positive & negative feeds on the instrument cluster's printed circuit. I would think more than just one gauge and a few dash lights would be acting up though.
chv5472
