Front disc dragging
heviarti
Emmett, Idaho
Buck
C25
383 Stroker
Has anyone here had trouble with one of the front disc brakes dragging? It seems that the left front has enough extra drag on it that it doesn't quite spin freely. Hub heats a little bit.
I took it apart, repacked the outside wheel bearing, cleaned up the two pins the caliper rides on, and greased the pins with some lubriplate. It does look like I'll need to do wheel bearings soon, but that doesn't answer for extra pressure on one side. I also popped the bleeder to see if maybe there was pressure stuck in the caliper. I only got the normal drip out of the system. Other ideas appreciated.
chengny
Dragging Brakes
FRONT DISC BRAKES
Causes:
1. Corrosion deposits build up inside of the caliper along the piston seal. This prevents the piston from fully releasing, and causes the pads to slightly drag on the rotor.
2. Caliper slide joints/pins binding. If the slide joints/pins are binding, the caliper piston will release the inner pad but the outer pad will remain in contact with the rotor. This is often indicated by the outer pad wearing much faster than the inner pad.
If the brake is locked up, opening the bleeder valve will release any residual pressure being held in the line by a faulty hose or master-cylinder. If the brake remains locked up, inspect the caliper piston and slides for seizing or binding.
Sounds like you've already eliminated the slide pins and residual pressure in the line. As above, check the piston for ease of motion back into the caliper bore - rust under the boot.
Jarhead79
Mt Vernon il
Michael
Get a new caliper, they're cheap, unless it is new than it could be a bad remanufactured part. Might clamp the caliper fully open then hit the brakes to close it, then repeat a few times, I'm betting a bad caliper though!
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
My brake lines were the problem. The right front would not release at times causing the truck to pull hard to the right. The rubber lines can collapse on the inside and act like a check valve, not allowing the caliper to release.
wheelie-schizes
