Front and rear 10-bolt guts the same?
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
From what I can find, the differential bearings and ring & pinion are the same for the front and rear 10 bolts. Am I correct or is there actually some little difference?
I ask because the place I bought my rear install kit from wants an extra $10 for a front axle kit that appears to be the same in the pictures, but I can't tell if the bearing part numbers are actually the same. I've also seen a lunchbox locker listed specifically for the front. Any difference there?
The front install kit might include the axle tube seals.
The locker is probably a different listing than the rear because there's no c-clips up front.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
That makes sense. Thanks.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Must be brand specific. The part number for the lunchbox locker I have in the front (Richmond) is also the same # as for a 10b rear.
j20owner
