From 350 trans to 400 transmission
silverlostdog
Hoouston
I have a 1977 C20 3/4 ton I'm in the process of swapping in a 406 small block. What will it take to install a turbo 400 Trans instead of a 350 Trans? Will I have to get a drive shaft made or is there one from another vehicle I can use.
Any info or assistance will be greatly appreciated.
Silverlostdog
74Blaze
Nashville, IN
Gerald
K5/Blazer
Not sure of the interchange with another vehicle, but if you need one made, I recommend Fort Wayne Clutch & Driveline. They've built several for me over the years and always have done a good job. They ship anywhere in the country.
NickTransmissions
Las Vegas
Nick
Silverlostdog
Have your existing drive shaft cut and rebalanced or a performance driveshaft made ss mentioned above. Trans cross member will need to be moved back which is straightforward...
What I normally do,build my combo,measure for a drive shaft and head to pik n pull armed with a tape measure. I can usually find something the correct length and replace the Ujoints. If you are lucky you may find another same wheelbase C series truck that came with a 400,grab it,and the driveshaft.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
I use a self built 350, 375 horse 454, six rear tires later, she still a peach
drowe14
