Frankenstein Gauge Cluster
Alright everyone, I'll be starting a build thread soon and will also have multiple individual threads for some of the individual little projects that make up the whole build.
The subject of this thread is that I am cheap and had some specific desires for my Gauge cluster. My original 1980 Gauge cluster is fully functional, but the lens is yellowed and does not have a factory Tach. I am swapping in a MPFI 454/4L80E/NP205 combo and will be switching to VSS from the mechanical output on the transfer case for the LS computer. I also am switching to a single Blazer fuel tank and would like a Tach. I can't stand the Tach screwed to the top of the dash or steering column and prefer the factory look. I also enjoy having the convenience of a trip meter. The simple solution is to just swap to a full electric cluster, but as I said I'm cheap and didn't want to spend $1000 on a new cluster.
What I have come up with it a Frankenstein cluster that I hope will work. I have sourced an electronic speedometer cluster locally from a 1990 Suburban with an electronic speedo and trip meter for $60. I have also sourced a factory Tach cluster locally for $75 dollars. All three clusters have a rough gauge lens that is really the only think remaining for me to complete the cluster. I'll post up some pics later tonight of all three clusters. Then I'll do a walk through of restoring and fitting all the individual components into a single cluster that hopefully does everything I want.
Does anyone know where I can get a new lens for a 1989-91 Suburban/Blazer cluster? I've searched and can't seem to find one for a cluster with the Trip reset knob hole. Would it work to get a 1987 cluster and just drill a hole for the trip meter knob?
80BrownK10
Greenwood, SC
Nate
Can you wet sand and then clear anybody the bad lenses to make them clear again?
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
I took mine apart and used a headlight restoring kit on it to make it clear again. No photos because I didn't belong to the forums back then. But it was much improved.
That’s what I’m planning on trying next. My original cluster Lens is fine except for the yellowing from UV. I have a high speed buffer, I’ll try wet sanding with 2000 grit and see what happens. Unfortunately the one from the 1990 is cracked, so I might have to try drilling a hole in the original lens for the 1990 speedometer. Here’s a pic of the new cluster with cracking damage. I’ll be picking up the Tach cluster tomorrow and will post some pics of that one and my original cluster then.
RoryH19
Rory
R10 Silverado SWB
I used the same cluster for my LS swap.
I added a tach to the open slot, bottom corner.
It's in my build thread below.
Nice, I've actually looked at that thread before. I like the simplicity of that small bosch tach you fit in there. Did your blazer already have an OD trans in it before the swap? I'm wondering if I'll have a hard time getting the gear selector to line up going from a TH400 to a 4L80E. I'm planning on using the newer style OD gear indicator from the new cluster.
jlyon1006
