frame paint
waterpirate
delaware
v10
5.7 tbi
Given that 90% of painting is surface prep, not product. Is the por15 worth the money over rustoleum? I have surface scale and normal lack of factory paint for a 87.
Opinions?
Rickf
Grafton NH
1974, 1954 & a 1937
I've used both and had better luck with por-15. You need to get rid of any scale for either to work well. Use a chipping hammer, needle scaler and lots of elbow grease to prep.
legopnuematic
Licensed Junk Dealer
MO
Spencer
On my 79 I am using Tamco's chassis black, cheaper than POR-15, catalyzed, easy to work with, UV resistant. POR-15 is some good stuff, BUT you cannot skip on the prep, use their degreaser and acid etch before application, and plan for a topcoat as it is not U/V resistant. Even though a frame is mostly hidden, it can still fade and will fade where light can get to it.
Core support painted with Tamco DTM Chassis black
Not the best picture, but if you look where the rocker is, the entire rocker box was prepped and painted with POR to protect it. This is on my friends 75 K5 that I am helping him on.
Doppleganger
OH-MI: Just like it sounds
There is a fella near here who blasts and repaints semi trailer frames. He uses the POR 15 exclusively as a primer. Blasts, POR, then several topcoats of tractor enamel. Said he's seen them 10yrs later and its still sealed.
ShortBus
Florida
Charles
V20
350tbi
Opinions?
I use Rustoleum Rust Reformer. Its $75 a gallon but its the best rust converter I've ever tried. Its tannic acid based. The gallon jugs are the real stuff, the spray cans are just regular spray paint.
If its just light surface rust I just use ospho.
mr4454
Las Vegas
Alan
I wire wheeled my frame, clean with degreaser, sprayed with Rustoleum primer-sealer, then chassis black paint. all for under $100
it turned out fantastic.
Remo76C15
Colorado Springs
Greg
C15
I wire wheeled, power sprayed with water, then POR-15'd it. Looks great.
rlfdavin
