Fouling issues
Slink
305ci
Mechanic tuned the carb and all for me, that is why I can at least get a day or two of driving out of it. He currently has the QJ and is rebuilding it. I ordered new metering rods today as the directions in the manual talk about doing for lean cruise. I will see if the rebuilt QJ does any better. I have a new mechanical pump that is a low pressure and appears to max at 5 or 6 psi. I also have swapped to E3 plugs to try and help if that matters.
bedwards
Adger, Al.
Bryan
c10 Silverado
That's soot. Running too rich or what plugs are you running? They don't look right.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Perhaps a dumb question- but are you sure the choke is opening and staying open?
Octane
Atlanta
Eddie
Hei runs best on old fashioned copper plugs in my experience.I replaced my dist. and plugs,and wires to fix mine.And as of now I've rebuilt the qjet carb. Got a brand new 40+ year old truck now! Lol
Slink
305ci
I’m running E3 plugs which have helped keep it running a little longer to troubleshoot and make changes.
Slink
305ci
I have watched it and have not seen it close unless I’m not watching right or giving it enough time.
Slink
305ci
I started with auto lite plugs and am running 8mm wires on new HEI distributor. I tried to go back with as close to stock as I could.
Octane
Atlanta
Eddie
I'm running a MSD Streetfire dist. and Taylor plug wires.On stock engine.With the qjet 4mv carb
Slink
305ci
Ok, gents don’t know if I fixed it or not will have to drive again and see. I swapped out the metering rods in the edelbrock. I went stage two lean on cruise as the manual called it. I was able to run around for over 30 minutes highway driving city driving and back road driving. At this moment it is not showing any issues.
bedwards
Adger, Al.
Bryan
c10 Silverado
I'd put a fresh set of plain copper AC Delco R45TS in it and run it for a 100-200 miles and post us pics then. They are the recommended heat range. I have had good luck with Accel plugs also.
Slink
305ci
Thanks [mention]bedwards [/mention] I will get a set and run them give it a shot.
Also, just so you can see proper choke operation(and because this video is cool as hell)... here is an old GM carburetor and choke description video
Slink
305ci
Thanks to everyone that has posted. After changing the metering rods out in the carb I have been driving it for a week with out any issues. Some hesitation in the throttle but I’m driving and enjoying cruising every afternoon. Thanks again.
starrrita
