Floor pan or patch?
snappchevy
Tennessee
Clay
Have some pretty good rust near the doors on the floor panel, would patching it up work or should I just put in a whole new floor pan? Rockers are bad too
jjester6000
Illinois
Jack
C1500
A couple of old license plates 'ought to bring that right back around.
It's that way on both sides? Likely cab corners too?
snappchevy
Tennessee
Clay
Nope the cab corners are in good shape, the floor pan is the only rust on the truck
curse
49002 portage mi
kyle
Mine is about the same. kick panels, floor panels, inner rockers, outer rockers. My cab corners are pretty good. Oh yeah, the floor supports are bad too
eskimomann209
Modesto
Marcus
If it were me, I’d cut them all out and redo. Floor, inner and outer rockers.
RoryH19
Rory
R10 Silverado SWB
As mentioned above, replace all and be done. Looks to be inner rocker, outer rocker, floor pan and probably kick panel.
Once removed you will be able to see the condition of the supports.
Cantrell299
