Kyle K
- Feb 14, 2020
- Charlotte, NC
- Kyle
- Chevy Blazer K5
Hey folks, question for you on floor pan insulation. I've removed all of the horrible old rhino line which was on the floor pans (miserable job). See photo. I'm going to put down some insulation under the carpet, and just bought this from Amazon (https://www.amazon.com/gp/product/B0751CBXBT/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1). This has the adhesive backing and should be fine, just don't think it will be great in the real hot spots.
I noticed when breaking in the new motor the floor pans get pretty darn hot near tunnel where the headers/exhaust run (basically along the line of the red battery wires under lead block in photo) . I was planning to put a more heavy duty heat insulation running front to back at this spot, and the other sound dampener rest of the way.
So my question, does anyone have any advice/product that is good for floor pan heat insulation installed in the floor pan? I'm trying to avoid installing on undercarriage as I'm going to coat that eventually.
Thanks!
View media item 9129
Thanks!
