codfish
Drive a hybrid. I NEED your gas!!
- Jun 9, 2022
- Newfoundland
- gary
- K10
84 K10
Dimmer switch on column
I haven't driven the truck much at night yet, but it's soon to become my daily driver, so that will change.
The 3 or 4 times I have driven it after dark, I've had a headlight issue. As far as I can remember, low beam is fine if I don't use high beam.. 90% certain.
High beams turn on, no issues. However after a few minutes, all 4 headlights (high beam and low beam) start blinking/flickering. Not a fast flicker, more like someone flashing their lights at you. And the dash lights and presumably the taillights are NOT affected by this. The last time it happened, I turned off the high beams and the low beams stayed on.
I have a new headlight switch installed already, to fix a dash light dimming issue. And I have 4 new headlights installed, as the old ones were fogged up. They are just stock type replacement bulbs, nothing fancy. I haven't driven the truck in the dark BEFORE I installed the new switch or lights, so I can't do a before and after comparison.
IF the new bulbs are drawing more amps than the old ones, is there something in the headlight electrical system that could be overheating and causing this to happen? Grounds all seem tight and clean.
I am planning to do the relay upgrade soon for the headlights. Just wondering if anyone has experienced this before and found a solution.
thanks as usual
codfish
thanks as usual
codfish
