mcarlo86
- May 17, 2019
- ND
- Brian
- Suburban
I have been thinking about towing our Suburban behind our motorhome when we go camping so that we have a vehicle to drive around if needed. I have some questions though. First off, would there be any concerns with the transfer case if towing at highway speeds for long distances? I have towed pickups before by putting the transfer case in neutral and I assume this should be ok with a NP241? Second question is about weight. I haven't ran our Suburban across a scale, but I would assume it is probably in the neighborhood of 5,000 lbs? My motorhome is a 25 ft class A with a 454, so it is a smaller class A and it seems to have plenty of power. Would I need to set things up so the Suburban brakes would activate to help with braking? Any suggestions on a good tow hitch?
