Chris64
- Sep 16, 2024
- San Diego
- Chris
- K20
So I've been checking off items to make this thing drivable and nothing's been easy.
Lights; I had no lights and no single problem. A few cut wires, a few chewed wires, a few bad bulbs and a few bad connectors and even some bad bulb sockets. I know have full lights (outside) blinkers, brakes and even reverse. Each one on each side was a fight.
Suspension; I had one broken shock and no others and a leaking steering stabilizer. I now have 4 new shocks and I have a steering stabilizer (but I'm waiting for that since I might need to do some steering surgery).
Brake fixes; new soft lines. I'll probably be replacing them for longer lines and I'm wondering if I should just replace the master cylinder because it's 50 years old. It seems to be fine.
ANYWAY, My son and I decided to take it for it's maiden voyage to get gas...it's on fumes on both tanks. The engine takes a really long time to warm up, but even warm it has a dead spot in the first part of the throttle. If I can get past that it seems to rev OK but this is an automatic so that's not really doable driving. So it stalls constantly. We aborted about 1000' out because the steering was super sloppy and I hadn't done more than a simple visual on it. It became very tricky when I had to turn around and go up hill. I couldn't accelerate without it stalling. It's idling was high enough that I was able to crawl home with just that.
So long story short; brakes seem good, steering is super loose (30 degrees of nothing between left and right) and the steering wheel is at 90 degrees (hopefully the last owner just installed it that way.
But none of that matters if the engine can't reliably idle or rev so that's my focus for now.
The stock carb and air-cleaner is what I have (for a 350, quadra jet I think they call it). I've been advised to get an Edlebrock AVS2 but I'd like to hear what others recommend. Is there a good carb/aircleaner combo that can bolt right on to stock? I've never dealt with carbs on a car.
I have not changed the plugs, checked compression, checked the timing or really done any engine work at all. I just checked the oil which looked good (the previous guy said he changed it). It was running (sorta) so I didn't want to mess with it. It sounds like all cylinders are firing but I could be wrong.
Or should I try to get the quadrajet working?
