Finding my ratio
rpcraft
Robert
Jimmy
LS 6.0 364 CID
it can and could but it always depends on how it breaks and if when it broke did it need to be replaced.... If it broke badly then they may have replaced it with an open diff, which is usually the easiest course of action.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Im tending to think its still factory guts due to me being only the 3rd owner of the truck. The first just used it to haul a set in camper and i personally know the guy i bought it from. Any insight on what usually blows in them? So i know what to look for while inside.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
When i pull off the cover ill take pics and post up. Idk when thatll be but... btw how gear oil goes in it?
CSFJ
Until it begins to run out of the fill hole.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
What breaks with the G80 can't usually be fixed because it actually fractures the carrier, so in the face of spending 500 or more dollars on a carrier, people usually opt to go with a wrecking yard open and rebuild that, or upgrade to something like an Auburn Gear LSD. Depending on where it breaks in the carrier sometimes it spits out the regulator and lock device, sometimes it spilts the carrier enough down the middle to where it spits out the spider gears and cross shaft. If it does option 2 you'll know it when the truck stops moving. Option one often leaves you able to keep on driving like as if you have an open diff, sometimes forever and then sometimes the carrier finally gives out and leaves you with a locked up rear end that won't rotate and most people do not realize they had a problem until they go to change the gear oil and find little springs and metal pieces of weird shaped doo dads in the bottom of the diff.
If you absolutely need a LSD, then moving on to something like an Auburn LSD, which uses a spring packed clutch and is pretty reliable overall is the best compromise overall. The next level above that is a detroit locker but I hear a lot of folks complain about the ratcheting on the rear end when they make a turn, and then the upper tier is something like an ARB air locker, which gives you the ultimate ability to have super nice road manngers, and a locked up diff when you need traction across the whole axle.
I think the quantity for gear oil is just a tad less than 2 quartz.
I know when I had my Ram quadcab it had a posi in the rear and I hated it on rainy days. It actually contributed to less traction because one wheel was already breaking traction so the moment you tapped the gas the rear end would get out of control fast.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Im not sure but i think i wouldnt mind it locked up so both wheels turn equally when i hit the juice.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Your 12 bolt is a limited slip clutch and sprin type not a Gov Bomb.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
If you watched the video the little stupid wind up thing will break and it won’t engage anymore. I’ve also seen the carriers blow apart. They usually a nice dent in the cover from the inside or tear a hole in the cover.
rpcraft
Robert
Jimmy
LS 6.0 364 CID
How can you tell when the RPO code says G80?
Wait, more specifically, what I mean is I thought G80 was the gov lock code, and if not what is that code?
rpcraft
Robert
Jimmy
LS 6.0 364 CID
This is my reason for asking.....
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
12 bolts didn’t have G bombs. 8.5,8.6, 7.5and7.6 10 bolts. My 12 has a clutch and spring limited slip and my front 10 bolt has a clutch and spring limited slip
rpcraft
Robert
Jimmy
LS 6.0 364 CID
Here it is. And ive spun them many times in the snow and it seems only 1 ever spins...
He posted this earlier while you were off doing whatever!!
ben_swager
