SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
So I need a filler neck for my truck, used is just fine, some rust is ok as long as it isn't to bad I can clean it up. This is for the passenger side, but I think they might but be the same.
So my truck has a dump kit on the factory box and I added the second tank which is the passenger side tank. So with the dump kit the stock filler gets turned so it goes in the rear fender area and extends upward in there instead of to the factory fill point. At the time I added the second tank, I could not come up with a filler neck so I bought a generic short straight filler neck. The problem with this is #1 filler neck is straight on with the tank so when full if parked nose up at all there is gas up against the cap. #2, It happens to be where one of the braces is for the box so that touches the cap and over time causes them to leak. I just had my third cap in 3 or so years since I added the tank to the truck start to leak.
So if someone has one of these laying around new or used let me know. Thanks.
