lcfman
- Aug 13, 2018
- Murfreesboro, Tenn
- Geary
- c20
I purchased a factory style conversion kit for my 77 C20 from Brothers. The kit included the tach, small fuel gauge, tach harness, circuit board sheet, and new lens cover. When I tried to install the kit the tach would not fit in my original 77 housing. The tach connections did not align with the original fuel gauge through holes. The tach needs a much bigger through hole to clear. As you may know the circuit board sheet is the wiring connection for this gauge cluster. On the kit as mentioned a new circuit board sheet is supplied. I compared the new sheet vs the original one and there are no connection points for the tach but there are 4 studs plus the wiring harness to the distributor on the back of the tach. Can I just cut a clearance hole in my housing to make the tach function? So far Brothers has not been any help. They said they would send me a housing that would work but so far nothing. Any comments welcome.
