Extended brake lines?
Lethermon
Sand Springs, OK
Noah
C10/C30
Wheres a good place that I can find Extended brake lines without dropping a fortune?
chevychase
va
chevychase
Get a line stretcher ..just joking . Try inline tube ..maybe local brake shop make you some.
Probably need for the front ..how much did you lift it?
8T6K5
AZ
L98 350 TPI
Local Harley shop, or similar, should have the parts to make your own. I did it that way when building my quad.
Lethermon
Sand Springs, OK
Noah
C10/C30
its gonna be an 8inch lift
I think it would be cheaper to build them myself a set is around 120
1986K30
Colorado
Sam
7.4L
Check with a local speed shop. I had mine built with SS braided lines for a lot cheaper than that.
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
How high a lift did you go with?.
Clayton
Craig794x4
Claveland
Robert
call rough coutry and measure the height of ur shocks installed
bcal
