Extended Brake Hoses
81K10EASTTN
TENNESSEE
RYAN
I’ve got a 81 K10 with a 4” lift. I got the truck the way it sits and the brake lines on the front were shot due to being extended to the max. I ordered the ones from skyjacker but my banjo bolt won’t go thru the fitting that came with the hoses. I drilled them out to fit the banjo bolt but I haven’t installed them yet. Is there a place to just get the fitting to screw my line on to? Also why is the factory line have the t shape?
MarineOne
Western New York
Factory line has tabs so it's easier not to rotate when tightening and classic tube in lancaster ny will probably have whatever your looking for
vr1967
Mississippi
Virgil
k1500
6.2L turbo
When I lifted my 84 k10, I used brake hoses from an 88 c2500 7200lb gvw truck.
If I remember right, the fronts were 4” longer than the originals on my 84, and the rear was about 3-1/2” longer.
Direct bolt ins and available at most any parts store.
ali_c20
Austria
Alexander
C20, K5
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria.
2manysquares2care
