Exhaust pipe kits from @mazon/ eBay
Matt Lutz
Bastrop
Lutz
250 4.1L
Has anyone on here purchased one of this type of kit to fab your own exhaust? I have a lot of welding and pipe fab experience, so that part wouldn't be too hard
legopnuematic
Licensed Junk Dealer
MO
Spencer
I’ve not used them myself, but I believe @Catbox had gotten some similar on close out from Eastwood(?), 3” diameter kits I think.
Rustisbest
Tennessee
6.1762844 liters
I've used similar kits to build 3 different exhausts. One kit did almost 2 other than a few bends and straight pieces and then I bought the Pypes universal x kit for my square.
I would step up to stainless or at least aluminized pipe. I like to weld most of it and put a couple of the accuseal style clamps in there to make it removable in sections. One of these makes for easy to weld lap joints and you can expand the joints a little oversize to cheat the bends for alignment if needed. Good luck
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
My buddy bought one from Amazon and the stuff rusted out within 2 winters. I would avoid unless it's stainless steel.
Catbox
Peter
C20 Silverado Camper Special
Yes.
We have used two kits from Eastwood and two kits from DNA on ebay / Amazon.
Wherever you can get the best deal.
For the raw steel systems, we just used barbeque black spray paint for corrosion resistance.
This is what was first put under my son's '49 truck, then he finished the tailpipes out to under the bumper.
Recently we built this set for my brothers '72 truck.
We live in an area that does not use salt on the roads during winter, so the rust out should take longer.
If it becomes an issue, the stainless option will be employed next time.
Matt Lutz
Bastrop
Lutz
250 4.1L
Yes.
Cool! I live in central Texas and never seen salt on the roads here in my small town. Thanks!!
EvilGenius
Metro Detroit
Darien
I really liked the DIY kit I got from speedway motors. The pipes are mandrel bent and thicker steel than what's on hand at the parts store. I bought a little section from O'Reilly to finish when I ran short and the difference in quality was significant.
Finkaire
Finkaire
California
Loren
Silverado c10
Hi all,
My ‘84 stepside is bone stock, ordered new. I have been searching for a stock tailpipe replacement 2 into 1 into 2 out one side and have not been able to locate. Not sure if all stepsides had that configuration or only with the glide-out spare tire carrier.
75 Chevy SWB 4x4
NE Oregon
Doug
K10 4x4
I bought a mandrel bent stainless steel Pypes Performance exhaust system for my 72 Monte Carlo, and it sounds and looks great. Exhaust system you is something you shouldn't cheap out too much on, otherwise, you'll be doing it again more sooner than later when the system rusts or breaks.
BrokeDaddy
