Exhaust manifold question
Ohearchai
Washington
Martin
V1500 Suburban
Well I thought this might be easy, considering no broken bolts or studs, but no.
Got a replacement, and yes it the same except for the flange where it meets the y.
Well the y pipe is this and it seems that the replacement is too long or is this a removable sleeve in the y pipe.
Any suggestions would be appreciated.
1lejohn
texas
john
k-1500, 2500 HD
Was the OEM one set up for the heat riser valve?
Itali83
Maine
Ben
K10, 'burban C10, Jimmy
Looks like the piece that’s missing on the old manifold compared to what’s on the new one is stuck in the Y-pipe.
PhotonFanatic
Arlen, TX
Wilhelm
Take the opportunity to waller em out.
That was probably it, no heat riser valve was on it.
Yep, the old one would have(should have) had a heat riser valve on it that would have made the connection correct to fit on the extension on the new one. Someone at some point probably removed the heat riser and modified the Y-Pipe, or the heat riser is still installed on the y-pipe in the truck.
seanhatesregister
