exhaust exit
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
try to built my rear tail pipe and exit to look like in the picture below...sould i buy stock tail pipe (straith side exit) and try to fit like i want or just buy a kit and make my own? ;)
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
here the space i have with out stock leaf spring and hanger in my way! ;)
Auburn, Washington
I’ve learned there’s some things best left to the pros, aka it’s pretty difficult to make a custom exhaust with a bunch of pipe and pre bent fittings compared to someone with a lifetime of fitting exhaust and the right tools.
Just gotta find a good old school muffler shop. They’re around but not plentiful.
Auburn, Washington
Looking at it again, you’re only modifying just the very rear portion of the tailpipe. Might be doable with an assortment of bends. But even if you can weld it together it will never be as clean as a single bent piece like the first pics.
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
your right on that but price go's up these days and a estimate at $800 at local shop..think gonna try and use my new welder and play with it! ;) like you said is doable for shure!
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
this will shure help too! :)
Catbox
Peter
C20 Silverado Camper Special
My son has fun with making exhaust now since I have bought him a welder.
Having the proper assortment of bends helps a ton, so find a good source for the size you want and buy plenty of them. And then some as you are bound to need to make corrections.
So far he has made several custom exhaust pipes for all different kinds of cars he and his buddies have.
I have found that looking around in the junkyard can yield plenty of those expensive exhaust parts for pennies on the dollar.
Just yesterday we pulled 3 tailpipes out with expensive Magnaflow exhaust tips on them.
They will be harvested for the bends as well as the tips will be cleaned up and reused.
Off a truck we pulled a nearly new looking Flowmaster and its whole new 3 inch mandrel bent exhaust piping. The tail pipes are $14 each and the muffler and its piping from the cat back was $35.
80BrownK10
Greenwood, SC
Nate
I want mine to look like that as well. The factory side exits rotted out on mine and I just have them hacked at the mufflers ahead of the axle. It's one of those to do things, and has been for years.
Auburn, Washington
That is a great idea, I never thought of that. To be fair, there are probably 100x more “good” exhaust systems under junkyard cars here on the wet side of the Cascades than many parts of the country though.
Catbox
Peter
I replaced the whole tailpipe section on my suburban for $14 and the pipe was nearly new.
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
did my first ever butt weld on flux core! i think i'm gonna be ok to built it myself! :D
TPISly-C10
Sly
C-10 shortbox
LQ4 6.0L
order from Walker 2 univercal tail pipe for GM $35 each and start from there! ;)
Craig 85
Nashville, TN
454/TH-400/NP205
Look at 64-65 Malibu/Chevelle tailpipes. They have a similar bend. Here's a set of 3" Flowmaster Tailpipes.
OEM Style
Flowmaster
70SBUDGET
SAN DIEGO
RYAN
K20 CUSTOM
Here is where I taught myself to weld when I did my 70 camaro. Unless someone is laying on their back hey will never know that it is your weld or a grease monkeys weld. Prebent pieces are cheap. Give it a shot!
seanhatesregister
