Fixed!!
I've done it! It's running!!
Here's what I did, in order:
- Installed a CLEAR fuel filter BEFORE the pump so I could see if fuel was getting to the pump
- Hooked a long fuel hose to the IN side of the fuel filter, and put the other end of the hose into a bottle of gasoline. When I cranked it, gas came out the other end of the fuel pump, so I knew that the pump is working good
- Hooked everything back up, put the carb on, and cranked the engine for 10 seconds. Looked at the clear fuel filter, no more gas in it now
- Found the fuel tank selector solenoid and started looking around. Found some really cracked rubber hoses and replaced them.
- Cranked for 10 or 15 seconds. Didn't start but this time I could see gas in the fuel filter
- Sprayed a little starter fluid onto the carb and cranked for another 15 seconds. Voala! It runs!!
Replaced two cracked rubber hoses. Here's the worst offender:
There's still some sun light left so I'm going to replace all the spark plugs and wires.
