grampsbutler
- Oct 3, 2021
- San Diego, CA
- Graham
- K10 Suburban
- 6.2l Diesel
I am new to Chevys, and have an issue which has me stumped.
I have a 84 Suburban K10 with 6.2L diesel V8. I have owned it for about 3 years, when I first bought it I had a charging problem, so I replaced the alternator and batteries. That fixed the charging issue, but now I have an electrical problem that is getting worse.
Symptoms: 1: The battery is going flat while driving....sometimes very quickly (after a 20 minute drive) I wont be able to restart. I will put it on a charger and batteries hold charge, but will will go flat while driving. I put a volt meter on the battery terminals and I am getting 13.4v running, which indicates that the alternator is charging. 2: The engine wont won't shut off with the ignition key. The dash lights go off, but the engine shutoff solenoid remains energized. I can usually get it to shut down by shifting into gear and then trying again several times.
I suspect the ignition switch is causing the shut off issue, The battery drain issue has me stumped. I have checked the harness for obvious shorts and or burned wires, and cant find anything.
Any suggestions what could be causing this would be greatly appreciated.
