jrdunham0826
- Dec 28, 2023
- North pole ak
- Jordan
- Gmc suburban 2500
Hi so I have a 1983 gmc suburban 2500 with a 350 small block and I live in Alaska so very cold outside. I have a heating problem my engine won't warm up to temp the highest temp I could get it to was 140 I used a ir temp gun to verify the temp. I replaced the tstat to a 195° it works I tested it before I put it in. I replaced the heater core, radiator, water pump, and flushed everything. And somehow the engine runs colder now that I replaced everything. I also blocked off the radiator with cardboard. And the fan clutch works. I am super lost and don't know what else to do I've tried everything that I know of. Any help will be appreciated thanks in advance.
