- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
www.truckandcarshop.com has a large selection of harnesses, both repro and NOS. However, They only have them for 73-82. As soon as I can find out if the 82 engine harness is compatible with the 86 I may be picking one up.
the only engine related stuff on an 82 is the choke, oil presure, temp gauge, ignition...unless you have the electronic timing with the knock sensor. what exactly are you trying to do?
He MIGHT be able to get this to work. The Engine Harness itself, should be the starter, Alternator, Dizzy Power, Gauges and Choke right??? I'd like to know for sure myself. I do know on the 81's, the AC harness is stand alone and not part of the engine harness, and on 81 and 86 both, the ESC harness is also stand alone. The engine harness comes out under the Brake Booster, the ESC harness comes out of he firewall in the hump just to the passenger side of the Dizzy Cap. The AC harness comes thru the firewall on the passenger side of the firewall also.
What I don't know, is if the Pin Outs are the same on the different years at the firewall off the fuse block.
