Engine stumbling/stalling in drive
DaytonaJuckes
New Braunfels TX
Danny
350 SBC
I have an 83 c10 with a new 350sbc. It’s been running like a champ for the last 3 months. As I had it out yesterday I noticed it started to stumble after letting up on the accelerator and applying the brake coming up to a light and it progressed got worse to where it would die. The engine idle in park is at 950 and after dropping it into drive it will drop to around 650. It’s never done this before and I haven’t changed anything. Thought it might be a bad ground as it was hesitating when starting. Worked on all grounds and now it starts just fine but it still stumbles after putting it in drive. I haven’t changed anything and now it’s dying. Can vacuum leaks just start all of the sudden. I also have an Edelbrock AVS 2.
fast 99
Spokane, Washington
Of course, vacuum leaks can be sudden as well as restricted carb circuits. Need to check both. Although I doubt it's the problem check fuel pressure and volume just to eliminate it. Idle vacuum steady?
DaytonaJuckes
New Braunfels TX
Danny
350 SBC
Vacuum is steady when it’s idle in park. As soon as it goes into drive it will stumble and eventually die. Park idle is 950 and drive idle is 650. Should they be that far apart?
fast 99
Spokane, Washington
Seems a bit more of a spread than is usual. Try adjusting the idle mix. Turn screws either in or out until highest RPM achieved then in 1/4 turn.
DaytonaJuckes
New Braunfels TX
Danny
350 SBC
I reached over and grabbed my distributor just for ***** and giggles and it was lose. I set timing again to 12° advanced and set carb fuel mix from scratch. Took it for a spin and it seemed to have slight bogging down like there was carbon buildup in the exhaust. I romped on it and it seemed to clear things out and run smoother. It stopped stumbling and dying at stop signs. It’s running fairly smooth but it still seems to be idling high when in park and a smidge low when in drive.
DaytonaJuckes
New Braunfels TX
Danny
350 SBC
I don’t know much about tuning these carbs so it time to learn. It seems like everyone has different terminology with carburetor components.
fast 99
Spokane, Washington
Be sure and check that both advances work.
DaytonaJuckes
New Braunfels TX
Danny
350 SBC
I did not. I’m learning a lot of this as I go. Didn’t know to unplug the advance. What does that do?
ChuckN
Bellinham, WA
Chad
You have two advances- one is under the distributor cap, the rotor is screwed to it. It is spring loaded (you’ll see that if you take the rotor off) and is a centrifugal advance. The rotor should turn in your hand and stop, and when you let it go, it should spring back.
The other is a vacuum advance- it is at the base of the distributor- It should be hooked up to the base of the carb via hose. The engine vacuum actuates it, and adjusts timing depending on how much vacuum it receives.
That’s a pretty basic explanation to get ya started.
2manysquares2care
