Camatruder
- May 11, 2016
- Belgium
- Rik
- K5 Blazer
- 350ci / 5.7l
Hi guys, I have an occasional hesitation and sometimes it even stalls. I also notice that I have a lot of white-gray-ish smoke when cold and a little of it when warm and at idle. The smoke does not smell sweet, it smells like ordinary exhaust smoke. When I’m parked and at idle and give it gas a couple of times there’s a puddle of water behind both exhaust. These exhausts are dual not connected lines and the smoke and water are the same at both. I’m not sure if the smoke and water have always been there and/or it is related. It’s not very cold at the moment here, about 9°C (48°F).
I don’t have any codes (except for 12 ofcourse).
Compression is good and the same at all cilinders. I tried a pressure test at the cooling system and I think it holds pressure (I had some problem with a home made pressure tester that I made in a hurry).
I have spark at all cinders also when acting strange during surging (I hope I translated this right, I mean that the rpm changed rapidly between 500 en 900 rpm at idle). I changed the plugs to be safe but it did not help. I don’t know how to check the quality of the spark.
Timing is correct (0° with the tan wire disconnected, 8° BTDC when it is connected). I could not check timing when acting strange as I could not trigger these events when I tested.
Vacuum is good and steady at 21Hg and is hold for hours after that engine has been shut off.
EGR valv seems to be in good working order.
My truck runs both on petrol or on LPG (propane) and this occurs on both fuels so it is not fuel related. In fact when it starts acting strange on LPG , the engine almost always stalls completely. I think this is because LPG needs a better spark than petrol.
I’m thinking icm or high tension coil or may be intake manifold gasket. Or maybe an out of control choke (i don't know how the choke is controlled in a tbi). I hate just throwing parts at it because these shipping and customs costs are too much).
This is my daily driver and need to solve this quickly (or just keep driving till I something gives).
Any input is highly appreciated.
