77 K20
- Nov 9, 2012
- Montana
- Mike
- K20 5" lift
- HT383 fuel injected
This thing is really starting to piss me off. Pretty much everything under the hood is new. After putting in the new engine it ran great for 6,000 miles or so. Then a while back I went on a 3 hour drive. Did great for 2.5 hours until I had to stop and make a right onto another highway. It started mis-firing. When I shut it off and let it cool down it will run fine again, but after about 30 minutes it will start missfiring/shuddering/shaking.
All ignition parts are new (6,000 miles on them). I replaced the ignition coil. No difference. Just replaced the cap/rotor/coil. No difference.
WTF? What can cause it to run great, then after 30 minutes of driving runs horrible? And then when you stop it runs fine at idle? When power braking it or putting it under load is when it really breaks up.
4-5 tanks of gas have been run thru it since the original incident also...
