Engine help
Caspian
Sapulpa, OK
Ken
R10 Burb
350/TH700R4
Valves are adjusted properly and still no go.. all spark plugs except #1 are covered in black soot, #6 and #7 are covered in oil as well.. I'm gonna forego all this and just pull a TBI 350 from the local pull a part as a short block and swap parts over.
Sent from my SCH-S968C using Tapatalk
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
Valve timing seems okay, maybe ignition timing is the culprit.
Sent from my iPad using Tapatalk
Caspian
Sapulpa, OK
Ken
R10 Burb
350/TH700R4
I thought that, but I've stabbed, re-stabbed, verified everything is getting a bright blue spark.. It's blowing oil out of cylinder 6, hence the spark plug being covered in oil.
Was truly hoping this wee oh five would get me by, it just expedited the 350 install :)
chevyk10
WV
Daniel
1984 chevy
k-10
Yeah oil blowing is not good. I'd say a compression check would answer a few questions.
5280k20
