Engine dieseling
1986k10
Delaware
Dale
Chevy 350 small block
I have a 305 and it's dieseling and I don't know why can someone please help please
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
First thing I would do is check your timing. If it's too retarded, in can possibly cause dieseling.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Idle is set too high, or the idle speed control solenoid is sticking open. Timing should be 4*BTDC.
Timing should be set while the trans is in drive.
Vacuum leaks will do it too.
79K10
Sacramento,ca
Ryan
350/th350
mine did that, i turned in the adjustment screws on the front of my edelbrock about a 1/4 turn and it stopped doing it
NastyNate98
