Engine Backfire Diagnosis Led to Wiped cam Lobes
350runner
tx
Ceasar
http://m.summitracing.com/parts/cca-12-231-2
if this is the cam your are speaking of then yes it would be a good one :) note you will have a smooth idling engine... No more race truck lope. Those flat cam lobes spell your 3 month problem out clear as day... kinda like I told you in that pm. I really wouldn't take a chance at not getting the heads rebuilt. 1. Those springs are prob worn out 2.valve or two might be gunked up and sticking.
firebane
Calgary, AB
Curtis
And make sure any new cam you install you run oil with either zddp in it or as an additive unless you want flat lobe again :p
Skweegle89
Oklahoma
85swb "Fancy"
What's the difference in this one and the one your running?
350runner
tx
Ceasar
Duration and lift numbers.
350runner
tx
Ceasar
Lil less intake duration, but pinch higher lift numbers
Skweegle89
Oklahoma
85swb "Fancy"
If I can find an engine stand the motor is coming out today. I want to take my time and do it right, and I really want to clean it up and paint it.
350runner
tx
Ceasar
Good deal. That cam will provide some serious low rpm torque and roast tires. I may do the same here shortly I'm really getting tired of these FN cold starts every morning. Really thinking bout going to the yard and getting an ls...
Skweegle89
Oklahoma
I don't want to go as far as dropping an LS in. So you think that cam that comp suggested is a pretty good bet? If all I am giving up is lope, then I don't care. I have listened to this thing lope in my driveway for so long without being able to drive it that I don't care if I never hear another lopey cam again lol.
350runner
tx
Ceasar
Yea that cam is good to go. You'll feel the throttle response is totally different.
Skweegle89
Oklahoma
Can I re use things like rocker arms or should I go ahead and replace them?
Skweegle89
Oklahoma
This is $75 cheaper on Amazon than it is on comps website. The kit their rep just tried to sell me was $554.52
350runner
tx
Ceasar
You can if they aren't bent out shape. And same for those push rods...
firebane
Calgary, AB
Curtis
LOL I had 4 back rockers. I went to the pick n pull and grabbed 4 good ones for free LOL.
Skweegle89
Oklahoma
mine seem to be ok. I will double check all of them. I am going to buy a whole new set of push rods. I will get the motor out today and with this nice weather coming this weekend, I will get the heads off and call the machine shop about getting them cleaned/fluxed and have the valves checked.
Skweegle89
Oklahoma
Anybody run one of these or heard anything about them? It will eliminate my need for an adapter and its only $112. And its polished, and that just looks good.
McLovin21
