Electrical Supplies
LDO
MS
Bob
Just curious where everyone gets their electrical supply stuff from. Relays, terminals, wire, etc..
I tend not to trust ebay when it comes to stuff like this....
yevgenievich
Place
Name
Year
Model
Size
Mouser, allied, Newark, digikey, and then there were a couple of more auto specific, but I have them bookmarked on a computer.
hatzie
k20
Mouser has a truly stupendous selection of Delphi Weatherpak, Metripack, Pak Con, Packard 56 & 59 terminals and connector shells.
Look in the wiring diagrams for the connector shell part numbers. Most of the shells that are not obsolete can be had from Mouser.
They also have most of the professional level tooling.
Deutsch and Amp AT, Molex GT, and many other connector families terminals, shells, and tooling are well represented in the Mouser catalog.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Gotten relays with the plugs in large quantities from ebay for years now as i need them. Only issue I ever had was that ive installed relays in locations prone to moisture and have had like 3 fail. For the price I cant complain. Ive run fuel pumps, air horns, train horn solenoids, starter kills, power locks. Like I said, only issue was installer error.
yevgenievich
Place
Name
Year
Model
Size
wirecare.com is another one for shielding
hatzie
k20
WireCare has some harder to find power distribution hardware. Stud strips, Buss Bars, Maxi-fuses, Crosslink Battery cable, and decent looking battery hookup parts.
WhiteProducts.com has Delphi M3382 compliant fusible link wire. They also have Delphi terminal crimpers and an inexpensive "cost Effective" tooling line that make passable crimps if you use em with care.
TheElectricaDepot.com has a lot of Delphi connectors in project quantities. This is a little mom-n-pop outfit run by a hobbyist that got tired of seeing 1,000 piece only minimum orders on the stuff he stocks. They also carry reasonably priced Delphi crimp and extraction tooling along with the tooling you'll find at WhiteProducts under the Cost Effective moniker.
The Wirebarn.com sells project paks of eight or eleven colors of crosslink polyethylene wire (GXL, TXL, SXL). Less than 250ft spools are hard to find. If you're lucky you can sometimes find 100ft spools. The wirebarn sells in 25ft coils rather than 250ft or 500ft or 1000ft spools.
OTOH if you want some 100ft, 250ft, and 500ft spools of GXL, TXL, and SXL wire... DelCity.com, WaytekWire.com, and AWCWire.com are good suppliers.
AWC Wire has wire with tracer stripes and sometimes has surplus leftover partial spools of wire for sale.
Delphi Electronics was a GM subsidiary that made GM connectors, controllers, and harnesses til it was sold off in the bankruptcy during the Obama Depression.
yevgenievich
Place
Name
Year
Model
Size
I have been happy ordering from TheElectricaDepot before, will be looking over the other ones.
echo7bravo
Alabama
Adam
K-10 stepside
350/Th400, 4.56 with 35" BFG MT
Mouser is quality!
brentjo
