MrMarty51
- Oct 25, 2012
- Eastern Montana
- Martin
- K20
So, what You are saying is that, the starter will crank the engine over but, only if it is hooked to a charger ??? if so then, let the charger do its thing for like at least overnight, then see how it cranks over, without the charger and, if it does crank over without the charger, does it then get spark.Now my truck will only turn over when battery is hooked up to a power source engine acts as getting no spark
Might be that the battery is so low that, while cranking on the starter, it draws enough voltage that it robs from the ignition.
