gmbellew
- May 27, 2018
- Kansas city
- glen
- suburban 1500
I had a high idle and surging issue after getting off the highway and/or long drives. I would also occasionally get EGR check engine light codes. I finally pulled the EGR, and it didn't seem to be in good shape. seems it is probably lazy closing after being open for extended periods of time.
I ordered a replacement ($65) from a parts house I have had good luck with and installed the new part. I immediately noticed an off-idle stumble once I hit closed loop.
hmmmm...maybe the EGR solenoid....$30 part later and I still have an issue.
it is definitely in the EGR arena, because when I plug the vac hose, I have no issues. until I cruise the highway and the ECM tries to look for the EGR and throws a code.
ok.....I have also had a couple random TPS low voltage codes in the last 6 months. one of them I even caught in aldldroid. TPS is a parameter for the EGR solenoid to open, maybe that is the culprit. so i replace the TPS ($65) and make sure the sensor harnesses are routed to avoid crossed/pinched wires. I still have the issue.
I start reading up on EGR and apparently some aftermarket parts are not correct (positive instead of negative backpressure) or are not designed correctly. I track down a Delco part (214-5073) ($100) that seems to be the correct part.
the new EGR shows up today. so I pull the aftermarket valve and do a side-by-side. I notice some subtle differences in appearance and in spring tension on the gasket. hmmmm....seems this aftermarket part isn't maybe right.
I install the Delco part, and finally all is good in the world. no more off-idle stumble. so, if you have an 87-91 5.7L half ton, your EGR is Delco 214-5073...there is NO SUBSTITUTE!
what a pain this was to track down...hope this helps somebody get to the finish line quicker than I did.
