84K30
- Jul 14, 2019
- SWPA
- Eric
- K30
Sorry for the delay, I have been working everyday since my last post. Definitely will have some time tomorrow to work on the truck.
I’ll recheck the plugs (and clean if necessary) beforehand.
Dumb question but should I work the throttle linkage to open the primary throttle blades when adding fuel or should I add fuel with the throttle closed?
Going to pull the carb to rebuild/clean it if Ricko1966’s suggestion doesn’t resolve the issue. I already have the kit and found a quality step by step video to walk me through it. Even if it’s just a diagnostic tool to rule it out.
Also, I did check that the distributor hold down bolt was still tight.
