Edelbrock 1405 carb running rich
iamtherealJayy
Tennessee
V20, K10, K10
I’m going to jump off the truck and get it to start first before changing the plugs just so I don’t instantly foul the new plugs. Hopefully burn out any residual flooding that happened from one of the floats pretty much touching the top plate. I believe it was the drivers side, with the top plate upside down it dropped the whole way to the top plate so it was way too high. I pulled the pin out bent it down put pin back in and the closest I could get was about 1/2” I couldn’t quite get to 7/16”. If it still runs super rich after the floats being set would the metering rods and jets be the last thing that could possibly be making it run so rich? When I get it started later I’m setting timing back at 10° with no vacuum advance since I haven’t verified whether or not that’s functioning properly. If it starts up and runs fine and doesn’t reek of fuel I’ll change the plugs. Also I have a hellacious exhaust leak on apparently both sides(noticed in video other day) I have replaced the exhaust manifold gaskets and it helped a lot but you can still see the pressure blow through it when it backfires. This truck has a janko exhaust in all honesty. The manifolds both leak and neither side had a donut for the rest of the exhaust so they both also leak, one side (passenger side) didn’t have studs it has a bolt going through the manifold to rest of exhaust with little rectangle plates to hold it together. When I got the truck the passenger side was so loose you could grab the tail pipe and rotate it every bit of 70-80° back and forth. Also the true dual exhaust had a different muffler on each side.
Blackbeard44
Washington State
andy
6.0 LS
if you have fouled out plugs that cant ignite the fuel properly it will smell very rich, its obviously not starting and to keep trying is only going to put adittional wear on your starter and battery, 10 degrees of initial timing is a little bit to much i think for a stock motor, 6-8 is where I would set it at. trying to run and tune a motor with fouled plugs is not going to be an easy task and its very likely that when you do change the plugs you will have to re adjust everything.
Blackbeard44
Washington State
andy
6.0 LS
an eaay way to test tje vaxum advance is to suck on the hose, than plug it with your tounge and if it keeps the vacum on your tounge itnis likely fine.
make sure the vacum advance hose is hooked to the partial vacum port on the carb, dont need constant vacum to the advance when at an idle only when the throttle is applied
iamtherealJayy
Tennessee
V20, K10, K10
You see someone previous said in this thread that on ported vacuum is incorrect and it needed to be on manifold vacuum and also said to go to 10-12 I originally had it at 8 I can set it back at 8. I have a brake bleeeer I’ll try and hook to vac advance and see if it holds vacuum
Blackbeard44
Washington State
andy
6.0 LS
vacum advance is used when you are driving not idleing, who ever said hook the distributor vacum advance to full time vacum is wrong
iamtherealJayy
Tennessee
V20, K10, K10
That’s what I thought I thought it was to advance timing to accelerate not advancing timing all the time because then your base timing would be wrong?
Blackbeard44
Washington State
andy
6.0 LS
I have seen motors run pretty good without any vacum to the distributor, its not an ideal situation but they can run pretty good without any vacum to the distributor
potent rodent
indiana
butch
86 and 78
350 and 305
I found this article while searching for good tech information on the comparison of ported vacuum versus manifold vacuum. I don't know the author so I can't give valid credit. ChevelleStuff.Net doesn't indorse either method and there is a lot of discussion as to which is better. So, I'll present the article and you, the reader, decide.
As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance.
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "****-bang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, drivability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
Courtesy John Hinckley
Retired GM/Chrysler Engineer
In this example of an Edelbrock aluminum carburetor, the MANIFOLD VACUUM port should be used for vacuum advance to the distributor and not the TIMED VACUUM for our Chevelles.
Replacement parts are necessary for all vehicles, and it can be difficult to choose the right parts for your particular model. Parts Geek has discount auto parts & accessories for both older and newer model cars.
Blackbeard44
Washington State
andy
6.0 LS
I could see manifold vacum being beneficial for a higher compression motor with a decent cam, but for a 70-80's stock chocked up 350 running on low octane pump fuel having that much advance from idle through the low to mid rpm range causing an issue with pinging, how was it hooked up before it acted up?
iamtherealJayy
Tennessee
V20, K10, K10
I’ve always ran it ported and not full manifold but it’s been on full manifold recently although pluggedcurrently
Blackbeard44
Washington State
andy
6.0 LS
if the motor is not running its not going to make a difference where its currently hooked up, have you messed with your truck today? did you attempt to start it? have you installed clean plugs?
potent rodent
indiana
butch
86 and 78
350 and 305
all my small blocks 305 and 350 are street driven on manifold vacuum advance on 87 oct, no pinging and running 12 btdc , i have a stop on my vac can that limits the can to 10 degrees so i will listen to a mechanical engineer that worked at 3 of the biggest corp
Blackbeard44
Washington State
andy
6.0 LS
i think it does have its place to be a vaible way to set up distributor advance, but I dont think having the op change his current configuration is going to do him any good, especially if further distributor vac can modifications are necessary to make it work.
potent rodent
indiana
butch
86 and 78
350 and 305
yes hes got other prob besides fine tuning his timing
Blackbeard44
Washington State
andy
6.0 LS
Backfiring and "puffing from the carb" could very well be timing related.
as far as I know no squarebody came from the factory with a locked out vac can setup for manifold vacum, so I wouldnt suggest someone having issues hook up the vacumn advance that way, if it works so good whats the need for a vac can locked at 10° does full advance happen way to early and pinging occur?
DaStrieg
