- Apr 11, 2017
- kansas
- Rick
- c20
The filter extension is included with a deep pan.
you can test the lockup pretty easy get the truck on a smooth flat road, hold the speed steady around 50mph. Don’t let off the gas, lightly tap the brakes. Tap the brakes just hard enough to turn on the brake lights, but not actually slow the car. If the converter works you will feel the engine speed up a couple hundred RPM, release the brake and the converter should lock again with a reduction of engine speed.
The filter extension more often than not is not included with the pan. When I was looking for a deep pan I found this out only 2 B&M and another brand I forget came with the extension. This was in the last 2 months.
Edited because I opened the amazon link and Read. The q and a .s
