Dually
Boonie
El Dorado, KS
Brent
DIY4x sells that whole assembly. it's set up for a narrower then stock front spring. but when I talked to them the guy said they could make me a set for stock springs.
http://diy4x.com/product.php?productid=17714&cat=250&page=1
highdesertranger
I talked to them, they told me that they could modify a set for stock springs, but it would toe the front of the springs out. I just figured if I could find a stock set somewhere it would probably be easier. DIY4X may still be the way I go, plan on replacing the springs at some point too.
Boonie
El Dorado, KS
Brent
Wonder if they make those in a 31x10.50x15....
They are treadwright tires. I didn't see a 31x10.5 in that particular tire, but they have one called guard dog that is fairly aggressive in that size. so far I'm pleased with them
ajd89
Central Michigan
andrew
hey friends, me again. hoping someone here can help me out. I am needing some front spring parts.
I basically need everything in these pics, the radiator support, the spring shackle, and that little brace behind them. Unfortunately, I need these for both sides. idk if someone here has a trashed frame lying around, or maybe there is a salvage yard nearby. idk. the yards around here have no squarebodies, ive looked. If someone could help me out with availability and a price, that would be great. thanks
Darn I knew this would happen I've had a front half of a k10 frame sitting around for a while the back was rust through cut it off and scraped that awhile ago but I scraped the front like 2 weeks ago
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
These are currently what im running on the back of my 2wd. $60 off craigslist.
Boonie
El Dorado, KS
Brent
yea, I scrapped the front of a k10 several months ago also. I have a k20 frame I could take them off of, just hate to cannibalize a perfect frame just for that. :banghead:
ajd89
Central Michigan
andrew
Right I agree
starrrita
